paul112004 Posted June 14, 2017 Share Posted June 14, 2017 Hello Apologies if this is in the wrong section not sure where I should post things like this . I have a focus tdci 1.6 mk2 56 plate and I think it's s dv6 engine I have changed my injector seals and oil ECT but I'm struggling with the injector seal protector When I put it in the hole it will only go down and bolt down leaving a gap between the bottom of injector and the metal plate but looking at internet photos they look to high to me as in picture 3 Does the plastic protector sit under the metal clip on pic 1 or does the protector push over that clip. Does the gap on picture 2 look correct in pic 2 as that is the gap when the plate sits on the protector I changed seals and copper seals but water went down the injector tubes when I sprayed water to test for leaks after fitting so they can't be sealed at the top and also they tick slightly but I smell no diesel fumes ECT from them so they must be sealed st the bottom. Thanks for any input Quote Link to comment Share on other sites More sharing options...
