tie bar/ rod
mrmetallica
does any one have a diagram of the tie bar/rod ? on mot last year they said had slight play in the ball joint so looking for a diagram so i know what t look for when i get under the car to replace it .
bump
some one must know .
the 'tie rod' goes between the steering rack and the 'tie or track rod end'
i should have said its the rear
I'm not aware of any ball joints on the rear of the focus
what exactly does the advisory on the mot say?
Just about to say the same,you beat me to it Stef.Balljoint at the rear?
it says tie bar/rod has slight play in a ball joint offside rear
only thing i can think of is that they are referring to the anti roll bar which has drop links/ball joints on either end of it.
As far as I'm aware the tie bar is part of the hub carrier.
its getting worse lol
The tie bar is fixed with a bush and bolts on the underside of the wheel arch.Correct me Stef  if I'm wrong.
so fords dont know what they talking about ?
I don't know buddy,I'm just offering my understanding of what a tie bar is,for what it's worth,lol.
im not having a dig at you mate . you know what ford are like ,they done the mot . ill have to crawl under and have a look
anyone have acces to diagrams of the parts at the rear ?
certainly was on the focus I've just repaired. you get a bolt and a ball joint type though. The ball joint type look exactly like the ones I've done on a mazda 3.
Yeah I appreciate that buddy,you really do have to nail them down to what they mean if you don't understand the description on  work sheets.It's happened to me many times,lol.
Isn't the tie bar the rusty curved link behind the spring in your photo?
No that is the rear upper suspension arm.
got a picture .i take it its the ball joint in picture ? what is the actual name so i can order a couple please
it wouldnt be the first time...............  :-D
and i wouldnt be surprised if this supposed defect  got absolutely no mention following an MOT from a trusted indepedent garage as my local dealership also has a habit of "fishing" for unnecessary work.
i would do nothing at this point until you can clearly hear or feel issues with the suspension otherwise you could be wasting time & money trying to fix a fault thats not actually there.....
or at least get a 2nd opinion
and to be fair , your undercarriage looks in pretty good condition in that last picture compared to the rusty piece of junk Stefs working on  ;-D...........
That's the rear Anti-roll bar link buddy.
ive been to garages that have tried to get work out of me . was told once the a ball joint was worn after id replaced it the year before ,so just cleaned it up went back and they passed it .thought fords would be better than that .
mot is up august so ill leave it see what happens .had them tell me my wipers need changing that was 5 years ago .still got them on and have passed every year lol
cheers mate . might be able to get some where now .
Yeah looking at the link I can see where the ball joint description comes into play,lol.
