able Posted June 17, 2017 Share Posted June 17, 2017 Hi I have a Dec2016 titanium Fiesta iam trying to get to the cig lighter to pick up a live feed any advise on how to remove gear lever cover so i can possible get to wiring . Is the cig lighter colour yellow and blue?? thanks able Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 17, 2017 Share Posted June 17, 2017 Does it need to be from behind the socket or would it be easier to use a piggyback fusetap from the footwell fusebox?Sent from my SM-G930F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
able Posted June 17, 2017 Author Share Posted June 17, 2017 Hi thanks for reply. ii did try the piggy back fuse from eBay but sadly it didn't fit the fuse box the adapter legs just where to short to connect , so I give up with that and now looking at making connection on back of cig lighter but can't get access to it Quote Link to comment Share on other sites More sharing options...
MJNewton Posted June 17, 2017 Share Posted June 17, 2017 The Fiesta fuse box doesn't suit many of the mini piggyback adapters however you should be able to trim away some of the plastic on the adapter with a Stanley knife or cutters and it'll fit right in. Quote Link to comment Share on other sites More sharing options...
able Posted June 17, 2017 Author Share Posted June 17, 2017 Yes I tried modifying by cutting away plastic but then the fuse next to it got in the way so I still could not get it inserted correctly. Quote Link to comment Share on other sites More sharing options...
MJNewton Posted June 17, 2017 Share Posted June 17, 2017 Ah, okay. I was probably lucky with mine in that I was piggybacking a fuse along the edge and so could face the adapter outwards. Could you do similar (choosing a different fuse, even an empty socket that still receives power at the right time)? Quote Link to comment Share on other sites More sharing options...
able Posted June 18, 2017 Author Share Posted June 18, 2017 (edited) Decided to try another option , removed usb facia ( interference fit ) identified live feed on rear of cig lighter through hole ( Yellow and blue ) still could not access wiring, removed passenger side trim on centre consol ( one plastic rivet at front then interference clips at rear part ) now identified wire in loom ( yellow/blue ) on the side going back to dash area connected a new wire ( used what I call a scotch block splicer ) going back to fuse area with a new 2amp inline fuse holder. still would like to know how to get the gear lever cover off did try a bit of leverage on chrom sides but no luck didn't want to damage area early post say just to pull upwards by hand?? Any advise. thanks able Edited June 18, 2017 by able Info Quote Link to comment Share on other sites More sharing options...
able Posted June 18, 2017 Author Share Posted June 18, 2017 Hi back again update . I eventually managed to remove gear stick cover ( it does just pull out from top very tight ) i used a credit card to make gap between chrome surround and bottom bit on passenger side I then inserted a thin 1in metal paint scraper blade between credit card and cover pushed inwards to release friction clips and generally worked my way around, at last I have got it off. I can now see the wiring on back of cig lighter and if I needed could now get to the wiring. hope the pic also help Quote Link to comment Share on other sites More sharing options...
