Jones93 Posted June 19, 2017 Share Posted June 19, 2017 Hi I have a mk6 2007 1.6 fiesta, the steering on it has goes hard when trying to parallel park and whines loudly. I've checked fluid and that looks fine, tyres are inflated correctly too. What would you check next? Only asking as pumps seem to be bit expensive. Thanks Quote Link to comment Share on other sites More sharing options...
karl46 Posted June 21, 2017 Share Posted June 21, 2017 If it needs a pump, then it needs a pump no matter how expensive it is. If the fluid is correct and tyres OK, no leaks and the drive belt isn't slipping then thats the initial checks, Jack the car up and see if the steering is still stiff. Find yourself an independant garage to get a quote. Quote Link to comment Share on other sites More sharing options...
