Hi There. I have a problem with water leaking into the front passenger well. It only happens when the aircon is running. It's also clear water (drinkable) with no signs of coolant or rust, so it has to be condensation from the aircon.
A friend says that the drain pipe will either be blocked or split. Can anyone tell me if this is easy to get to without taking the dashboard out? Can it be unblocked from below the engine for instance?
hi jake, how bad is leak, have you checked under carpet for any floor pan holes ? was the water still coming in on recent hot days ?
cause i did have issues where i had went passenger floor but it was due to it coming through elsewhere, which i sorted
