Mrxhris
Whining noise
Hi.  I need some advise please.  Our 05 plate fusion has a whining noise. It's not engine related
The noise sounds like the one you got as a kid when you placed a blade of grass between you thumbs and blew across it
 Here are my observations
It only occurs  at about 75mph or above
Open a window a crack it stops.
if driving into a wind it starts at a lower speed.
with a tail wind the starting point is a higher mph
heater fan or off has no effect
postion of air flow has no effect.
I suspect the onset is air pressure related
Has as anyone ever had a similar issue  or heard of itand if so  how was it solved or where do I start looking to solve
many thanks
chris
I
Check there's nothing caught underneath the car, also check there's no dry leaves caught anywhere in the engine compartment that will rattle about as the draught catches them! (You'd be amazed how loud a trapped leaf can be)
