Wiig Posted July 3, 2017 Share Posted July 3, 2017 Hi. My AC on my FF 2006 MK II 2.0 is getting really noisy . I got the aircon pump changed in januar 2016 , and got gas refilled . But when the temp rises , in the summer , the noise rises. What is the problem ???? Wiig Quote Link to comment Share on other sites More sharing options...
Dave1981 Posted July 3, 2017 Share Posted July 3, 2017 When was the air con belt last changed? My mk2.5 has noisy air con. A high pitch whine after a few min of running. Turned out to be that it was low n needed refilling and also the belt was worn . Quote Link to comment Share on other sites More sharing options...
Wiig Posted July 3, 2017 Author Share Posted July 3, 2017 The belt was changed in 2014 . My noise is like a bad bearing . And it dispeares when the AC is shut off. But the pump is almost new , so i doubt that the bearing is worn. Wiig Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted July 3, 2017 Share Posted July 3, 2017 I have 2010 ford focus 1.8 petrol the aircon has always whined since i bought the car at 18k and 3 years old I always thought it was normal. It has never got noisier. Quote Link to comment Share on other sites More sharing options...
Wiig Posted July 3, 2017 Author Share Posted July 3, 2017 I have owned 2 other FF MK II , with AC , and none of them whined/rumbled as much as this one. And it is driving me nuts Wiig Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted July 3, 2017 Share Posted July 3, 2017 Can you put a video on? 1 Quote Link to comment Share on other sites More sharing options...
Wiig Posted September 7, 2017 Author Share Posted September 7, 2017 I have contacted the garage where i got the ac pump 2.5 years ago , and the pump is done , so new one , again . Why is the pump beaking down ? The original pump was noisy as this one , and now it is the same . On my car there is a belt going from crankshaft to the pump , NO extra wheel , how is it on eksample the newer ones FF 2.5 and 3 models?? Wiig Quote Link to comment Share on other sites More sharing options...
isetta Posted September 8, 2017 Share Posted September 8, 2017 how is the belt tensioned? is it by moving the pump on a pivot? perhaps overtensioned when fitted and that puts too much strain on the bearings (at end of crankshaft and aircon pump) Quote Link to comment Share on other sites More sharing options...
Dave1981 Posted September 8, 2017 Share Posted September 8, 2017 If it's like mine then when you fit it you use the supplied tool to guide it into the pulleys.. no pivots on either end Quote Link to comment Share on other sites More sharing options...
Wiig Posted September 9, 2017 Author Share Posted September 9, 2017 16 hours ago, Dave1981 said: If it's like mine then when you fit it you use the supplied tool to guide it into the pulleys.. no pivots on either end It is like yours , no pivots at all. A speciel tool to get it on the aircon and crank wheel. But in my head it is the wrong way to have it like this , you cant tightned it at all , it is on or not. Wiig 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted September 9, 2017 Share Posted September 9, 2017 stretchey belts give the correct tension. Quote Link to comment Share on other sites More sharing options...
