P1nky Posted July 3, 2017 Share Posted July 3, 2017 Aircon issues. Please help! I have a MK4 Mondeo 2012 plate. I recently had the condenser changed due to a bird strike. Condenser was changed and the system regassed. The aircon was working fine, blowing approx. 5 C at the vent. Everything was working fine until the period of hot weather. I was driving, aircon working fine, stopped and parked for about 15 minutes, when I restarted, the aircon was blowing outside air. I took it back to the garage that carried out the work and the pressure in the system was just above 12 bar, they also could not drain the system. I carried out some investigation. When I press the aircon button on idle, there is no drop in revs The compressor fails to engage The 15A fuse is good The cooling fan engages as it should when the engine gets hot. There are no codes on my OBD reader On the aircon self-test (I have the touch screen) it has 2 error codes 0xff and 0x4f, I have no idea what they mean or where I can find that info out without paying Ford. I drained a bit of gas to see if it had been overfilled (high pressure switch) What should I do next and / or what do people think is wrong? Quote Link to comment Share on other sites More sharing options...
