Kylinski
Rear screen washer bottle location?
Hi folks
2017 Mondeo ST
I can't find my owners hand book.
Does the front screen washer bottle also service the rear screen?
Or is the rear screen bottle in a different location ( the rear has stopped working, I presume the bottle is empty )
I take it the front still work and you can hear the motor trying when you wash the rear screen? I'm sure the Pipe runs up the off side a pillar and through the the rear of the car and then into the boot lid through the rubber casing. I guess it could be 'pinched' there or the tube could have popped off at the bottle or the rear window
Yep, the fronts are working fine, and the motor is working on the rear, just no water. Filled the bottle to max level.
I've had issues with the rear washer on previous Mondeo's. When you try using it, is there any fluid under where the washer bottle is located? It could be the tubing is disconnected underneath. Can you smell the washer fluid when you're in the car? Another area it can become disconnected is around the a pillar in the back
