bt_cav
Fusion Front heated windscreen
27 posts in this topic
Thanks for the picture guide, my connections seem ok, but maybe the nearside one was a tiny bit loose. Have re-connected and will see in the morning if cold enough if it has made any difference.
Here are today's findings - drivers side connector was a bit loose, and there is also a small tear? Is this the cause of the fail? can't tell today as not cold enough.
And why is damp getting in the car - hang on if you remove the rain drain from the end of the scuttle - the screen rubber has a gap - is this causing a problem? Should it be like that?
