Trillionz
Emergency funnel alternative????
22 posts in this topic
Anyone discovered a household item that can be used instead. I am not about to pay £7 for a plastic pipe. I went through some of my sockets to see if any of them would fit just to size it and I found that the 17mm one does. Vernier reading of 24mm. Looks like the handle on the garden rake is this size so the next time I get the car out of the garage I'll try it for size and cut a bit off if it works.:smile:
It's not just the size, I believe it's 'keyed' (very basically).  Just pay the £7, keep it in the car and never think of the £7 again. I suspect most here have just bought one.
Russ and trailertrash like this
The spout on a 4 gallon army Jerry Can Is what I use. Ideal!
Trillionz likes this
Sent the wife to check the caravan water carrier.:wink:
Edit: water spout right size to start with but tapered.
Found this though:- will see if they will let me try one £3.19. http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/car-cans-and-funnels/fuel-cans-accessories/?549779981&&cc5_147
I thought there was a extra tab of plastic on the official ford funnel which was required to open the neck? I guess not!
It seemed strange to me that when you look at the ones for sale on eBay they have a range of years that they work on. Yet aren't all the diesel pump nozzles the same when you fill up no matter what you've got?????????:biggrin:
iantt likes this
It seemed strange to me that when you look at the ones for sale on eBay they have a range of years that they work on. Yet aren't all the diesel pump nozzles the same when you fill up no matter what you've got?????????biggrin.png
Yep, only difference is diesel or petrol versions
5 minutes ago, Philf1 said:
Try a shewee
www.tomholroydphotography.co.uk
That is what comes up if you search on amazon for one.:biggrin:
good grief , you really wanna risk wrecking your filler spout to save 4 quid ?
yeah good luck with that.......  :-/
1979Damian, iantt and Stoney871 like this
That's the one I use
£7 is a small price to pay,but if it hurts you that put paying that, take the car back to where you got it from and tell `em the funnel was missing from the car :w00t:
Stoney871 and 1979Damian like this
Just to check, you've looked in the spare wheel well in and around the foam/spare wheel (if you have one) for it? I found mine hiding underneath the foam sort of wedged in.
Yes I have checked, It is the principal I object to.not-gonna-take-it-twisted-sister-were-no
Can't remember the last time I had to fill a car up from a can just make sure you don't run out of fuel and your principles won't take a hit
I have just got this car and it has been doing 2miles a day for the last 4 years so its all choked up. I want to put a bottle of Redex in £10 worth of diesel,warm it up and drive it around at 4k revs to clean it out.:wink: But I can't get the Redex into it without a funnel. I could go the fuel filter route but I don't want that much carbon dumping into an already choked exhaust. :ohmy:      https://www.youtube.com/watch?v=D8RfoL7aZJo&t=75s
take it for a good blast down motorway and fill up with shell/bp premium as it has the additives in it all ready.
i take it the old owner of the car was doing 2 miles a day in it for 4yrs and not you if you have only just got the car
That's not a principle it's just you being tight.
1979Damian likes this
I have just had £7 in my hand whilst I looked in our recycle bin and I can't see one bit of plastic in there that is worth £7.:biggrin:
keep that £7 in your hand ready to invest in a proper funnel and then it`s job done
Come the Zombie Apocalypse I don't want to be siphoning fuel out of all the dead cars and trying to put it in mine with the emergency She-wee. I'm with John and an army jerrycan as weapon of choice. :wink: As soon as I've got my car on the road I'll report back when I have tried one.
the last thing you`ll be doing it siphoning fuel out of cars if your a zombie :yawn:
