Ford reverse camera help (Factory fitted)
jace1969
 Share
Which fakra connector is the one you will be keeping? Is the one I have circled the one that is on the cars loom, not the old camera?
Link to comment
Is there any idea what the name of the black small connector is as i have worked out the 3 wires on it as
i need to re join this one next.
Link to comment
  • 3 weeks later...
Any idea what the small black connector is as i have sorted out the 3 wires.
It comes apart on the left side where it goes from small to large so it the male end i need,you can
just see the little tab that i pushed in to release it.
Link to comment
The only other way is 3 scotch locks or something like that onto the loom wires.
Link to comment
I'm not sure what the connector is called, sorry. I used scothlock on mine but for some reason they didn't work
Link to comment
Cheers Jon you have been a great help,ordered some scotch locks so see how it goes.
Great to have all the wires there and working so its just clip them on to which camera i use,got all camera and just waiting
on one lead then its converted from £150+ camera to a £6.99 one,in total with leads comes to £15
  • Like 1
Link to comment
Ok after having all the leads come i have found out a few things and also have 1 problem.
I don't need reverse live feed and ignition feed as one works fine.
I get a picture but rolling bad,what could this be.
Link to comment
  • 1 month later...
Ok got this all set up as good as but i keep getting a rolling picture,is this the Fakra lead being its the picture one thats not connected right as it with a fakra
to a phono type to connect to the new camera,not got the 2 power ones connected as tried the 2 separate and dont make any difference.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
