elrasho Posted August 15, 2017 Share Posted August 15, 2017 Hello. Recently my LG G4 and other phones wont connect to my cars bluetooth. It successfully matches the PIN number but when I go to pair the LCD display says "waiting for phone authorisation" and wont move from there. Eventually it says failed to connect. Any advice would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted August 15, 2017 Share Posted August 15, 2017 Have you tried a master reset? Quote Link to comment Share on other sites More sharing options...
elrasho Posted August 17, 2017 Author Share Posted August 17, 2017 Yep I tried a master reset, it took a few minutes then said Master Reset Successful. Quote Link to comment Share on other sites More sharing options...
jakerwalton Posted August 18, 2017 Share Posted August 18, 2017 On 15/08/2017 at 0:14 PM, alexp999 said: Have you tried a master reset? How do you do a master reset on these headunits? I have the preface model, but struggling with bluetooth issues. Disconnected the battery but didn't resolve the issue Quote Link to comment Share on other sites More sharing options...
alexp999 Posted August 19, 2017 Share Posted August 19, 2017 Master reset usually refers to the sync procedure. How new is the phone you're trying to connect? Disconnecting the battery often helps. Otherwise try disconnecting the module in the footwell and reconnecting it. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 20, 2017 Share Posted August 20, 2017 Maybe it's a connection fault with the phone? Quote Link to comment Share on other sites More sharing options...
elrasho Posted August 23, 2017 Author Share Posted August 23, 2017 SYNC wont connect to any phone though. If I disconnect the battery, how long do I leave it disconnected for? Quote Link to comment Share on other sites More sharing options...
elrasho Posted October 2, 2017 Author Share Posted October 2, 2017 Since replacing the battery in my key fob the bluetooth has started working again. Quote Link to comment Share on other sites More sharing options...
