Martin-Fiesta-MK6-1.4
Drive Belt fitting without A/C
Hi, im looking to fit a new drive belt (fiesta 53 duratec 16v petrol) could someone be kind enough to give me a simple guide on how to do this? i know i have to remove the offside headlight and grill, i just need instructions on the actual belt removal and fitting, thankyou :)
No need to remove the headlight or grill to fit a drive belt. Remove the wheel and part of the arch lining covering the pulleys.
they are stretch type belts so to remove the old one it's easiest to cut it. To fit the new one some belts do come with s fitting tool, otherwise you can buy one seperately. Otherwise you can red neck it and do it with screwdrivers if you are feeling brave and want to risk the new belt lol.
42 minutes ago, Martin-Fiesta-MK6-1.4 said:
is it easy for someone with no mechanical experience to go red neck? for this particular job lol
I would advise against it lol.
Can I ask, if your car is needing a drive belt - has the timing belt ever been changed?
yeah i had my timing belt changed 8 months ago, why do you ask???
if it has then chances are the aux belt was changed at the same time(or should have been) as streatchy belts should be one time fitment, cut them off to remove before doing cam belt.
ok so from watching youtube tutorials im gonna do the following...
1 take wheel and plastic guards off
2 cut off old fan belt
3 attempt to thread the new fan belt around the cogs using my hands
anything else i need to do??? lol
im ok if i fail my cousin is a mechanic but i really want to learn how to do these things by myself
