AdBlock Warning
Jonanstee
coilovers or uprated struts and lowering springs?
Now before anyone mentions it, i know cheap coilovers are not amazing hah.
The question is if they would be better than getting uprated shocks and lowering springs.
Only looking to spend a few hundred on these was just looking for recommendations and opinions.
im old skool so i'd go for uprated shocks + matched springs
i'll leave the coil over kits for the kids in skinny jeans & baseball caps......
The ones with their wheels pointing outward on the bottom 😂😂😂😂😂
Exactly right lol, when you have your kit fitted I would as the car will be lowered an sit differently from standard have the suspension set up, preferably  an all corner set up this will mean for better handling as the angles and steering geometry  will be right and your tyres wont scrub  then I've seen an all corner set up for abought £95 (if I remember right) for the sake of a bit extra its worth doing right.
anyone found recommending extreme positive camber kits on this site can expect a right good public flogging.......
1 hour ago, Jonanstee said:
thats a damn good price for eibach.....
Quote
they are bog standard shocks that will offer no handling improvement over what you already have on the car
to get the full benefits you really need a full kit where the shock pistons are shortened to compensate for the drop in ride height , and the damping rate is matched to the spring compression
which basically means a kit where shocks & springs are sold together , like on the demon tweeks link i posted.........
