AdBlock Warning
ZetecMan1
Engine under tray
2 hours ago, Devonboy said:
I had a Peugeot 207 that failed the MOT because the examiner could not see above
They cannot fail because of trays and panels etc... they can give you advisorys stating unable to check. if that was the case most modern cars would fail the mot some of the audis nearly all the floor is covered with plastic undertrays you cannot see if the car is rotten etc... the MOT tester is not allowed to remove panels for example I had a car with a missing wheel nut so popped a wheel trim on that wheel and it passed the MOT (yes I did replace the wheel nut)
