englishl1989 Posted August 18, 2017 Share Posted August 18, 2017 Hi All, Just purchased my first ever ford. A 2012 Focus Zetec Does anybody have any idea what these two blocks are above the rear view mirror? I assume they provide some sort of 12V feed. But what to? And what is it's intended purpose? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted August 18, 2017 Share Posted August 18, 2017 These are the ground connections of the heated windscreen. 5 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 21, 2017 Author Share Posted August 21, 2017 Thank you! Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 21, 2017 Author Share Posted August 21, 2017 Is there meant to be something that covers them? Or do all focuses look like that. What makes me ask is the cut out from the roof lining.... Quote Link to comment Share on other sites More sharing options...
Russ Posted August 21, 2017 Share Posted August 21, 2017 5 minutes ago, englishl1989 said: Is there meant to be something that covers them? Or do all focuses look like that. What makes me ask is the cut out from the roof lining.... Does the windscreen have Ford stamped on it, if not, the windscreen may have been replaced and someone's cut the roof lining to aid removal of the screen? Quote Link to comment Share on other sites More sharing options...
iantt Posted August 21, 2017 Share Posted August 21, 2017 there should be a cover. 1 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 21, 2017 Author Share Posted August 21, 2017 Yes the windscreen has been replaced before I purchased it. So I guess the cover has been removed and not replaced. Does anybody know what cover / part number is meant to go there so I can order one ? Ive seen a rain cover which looks like it could go there but I am not certain. Quote Link to comment Share on other sites More sharing options...
iantt Posted August 21, 2017 Share Posted August 21, 2017 mine has got the rain sensor so slightly different. thatd the one part , then another small cover fits the other side of mirror in your case. will look on eBay and see if i can see what you need. Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 21, 2017 Author Share Posted August 21, 2017 Is this the one ? Quote Link to comment Share on other sites More sharing options...
iantt Posted August 21, 2017 Share Posted August 21, 2017 thats what ive got, but not sure if it will be the correct one for you, i will tag clive @stoney871 and see if he can identify the part numbers. if not, a can find out tommorow for you. 1 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 21, 2017 Author Share Posted August 21, 2017 Thanks Ian. Appreciate it! Have a nice evening Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 21, 2017 Share Posted August 21, 2017 Thanks Ian. Appreciate it! Have a nice evening If you can P/M me your car registration or VIN then I'll search microcat for you and be 100% sure you are pointed towards the right part.I'm pretty certain that the one you located on eBay is only for cars with rain sensors fitted. Sent from my SM-G930F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted August 21, 2017 Share Posted August 21, 2017 thanks clive 2 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 21, 2017 Share Posted August 21, 2017 Having exhaustively scanned Microcat I have come to one conclusion- Luke, There are no covers missing from the car. What it appears to be to me is that the two black covers have been slid down or cut short, possibly you can slide them back up again? That loom tape covered wire is most likely a non standard wire, likely run to that location for a dashcam or suchlike or possibly a non standard connection to splice the heater matrix as the original was damaged when your windscreen was replaced? Slide the right hand cover down more to check or see if it is/not connected to anything? That sticky pad marked bit (circled in picture) lends more weight to my theory that there was a dashcam stuck there. I know this doesn't help to cover the chunks missing from your headliner but there really are no covers listed for the mk3 focus unless it has rain sensors fitted. 1 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 21, 2017 Author Share Posted August 21, 2017 Thanks for taking the time to look Clive and for your detailed explanation. i will take a look tomorrow and report back... i actually plan on installing a dash cam in that position - so that would be a result if that was a constant 12v feed. Thanks again, speak more tomorrow 2 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 22, 2017 Author Share Posted August 22, 2017 20 hours ago, englishl1989 said: Thanks for taking the time to look Clive and for your detailed explanation. i will take a look tomorrow and report back... i actually plan on installing a dash cam in that position - so that would be a result if that was a constant 12v feed. Thanks again, speak more tomorrow So I've taken a look this evening, the wires are the same on both connectors and there doesn't appear to be any unused wires above the roof lining. So I assume they are the original wires. They connect to the windscreen pins. The windscreen is not a ford windscreen. Will a rain sensor cover not just fit over the top of them? As long as I can make it look a bit neater I am not bothered if its not a perfect fit. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 22, 2017 Share Posted August 22, 2017 You could probably fit a sensor cover but because that area is blacked out normally it may look a bit odd having an empty cover there.Maybe get a bit of dark window tinting film put there and cut to size?Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
iantt Posted August 22, 2017 Share Posted August 22, 2017 im wondering if the windscreen is wrong? mine didnt have rain sensor but has the covers for it with the circle that sensor would sit blacked out. its a bit of a strange one. the cut outs in lining match my cut outs 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted August 22, 2017 Share Posted August 22, 2017 think you need to find another focus of same age and zetec and have a look. see what covers there are. 1 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 22, 2017 Author Share Posted August 22, 2017 Yeah I think you may be right. Thanks for your help. If I find a resolution I will report back... Might be time to get my 3D printer out... 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted August 22, 2017 Share Posted August 22, 2017 unfortunatly i dont work at a normal ford garage anymore or i would have had a look for one by now. all i see are new ones now. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 22, 2017 Share Posted August 22, 2017 Maybe this part could be trimmed and modified?- http://www.ebay.co.uk/itm/272768399371?clk_rvr_id=1290841319009&rmvSB=true Quote Link to comment Share on other sites More sharing options...
Swiftfocus69 Posted August 24, 2017 Share Posted August 24, 2017 Luke Just looked at my MK3 Focus 2011 Zetec, with Heated screen. ( Not been replaced ) Mine looks the exact same as your pics posted . 1 Quote Link to comment Share on other sites More sharing options...
englishl1989 Posted August 26, 2017 Author Share Posted August 26, 2017 Ah really...thanks I was worried i was missing a part! Weird that they haven't made it flush with the lining isn't it ! Quote Link to comment Share on other sites More sharing options...
