AdBlock Warning
CrazyInWeston
Ford 1.6 Ti-VCT which fuel to use, Super or Normal?
Hello all,
I have researched for hours, days, and cannot find SPECIFICALLY as to whether a 2005 Ford Focus 1.6ltr Ti-VCT engine is better on "super unleaded" 97-99 RON vs 95 Ron.
All I want answered is a simple Yes or No.
Seen too many threads turned into a war between people who claim they work or its a con, but none talking about this engine specifically.
So THANKS for those IN THE KNOW about Fords 1.6 Ti-VCT engines and their experiences.
cheers.
You can use Super if you want but you don't need to; the engine is designed for a minimum of 95 RON.
If you did put Super in it you'll probably find it runs slightly better, gives a bit more torque lower down and you'll see a slight increase in MPG.
I have the Mk3 with the same engine as yours and I run it on Tesco Momentum 99 and I find it makes the car run better and my MPG improves from 39mpg to 42mpg; but it's purely up to you, the engine doesn't need it like others.
Thank you for taking the time to reply iFocus, I will give it a try. Havent been to my local Tescos for years since I work and therefore shop at a different supermarket for convenience purposes, but the store I work at doesn't sell any super unleaded and the rip off prices I see from my local BP and Shell have always put me off, they're about 20p a litre more than their standard stuff. I know BP's ultimate is £1.36 p/l vs standard at £1.16 p/l, Shell is same price standard as BP but £1.32 p/l for their V-Power. I'll have to see if my Local Tesco's sell "Momentum".
theres nothing specific about the ti-vct engine that requires it to use higher octane fuel
and "better" is a relative term , so while there maybe marginal benefits to using it , whether this is worth the extra 10% or so additional petrol costs is down to each individual to determine.
personally i'd say not worth it tbh from my own experiences
Thank you biff55 for your input, as I said in my previous post, if my local Tesco sells Momentum I might give it a try, and see what my experiences are. I'm not paying them Shell/BP prices.
Every premium fuel is normally about 10p more than normal. You must have some seriously profiteering stations near you!
My local station is 1.179 for Momentum vs standard at 1.139; but the extra cost is mitigated by the difference in MPG.
Most premium fuels are about 10p per litre dearer for 97ron, momentum99 is usually 4-5p dearer so better value for sure.
You won't notice a thing!
I didn't on mine, on a car this old, it doesn't feel eny different. I tried a couple of months each on Shell, BP and Tesco's premium fuels without any noticeable MPG different, or responsiveness.
I notice responsiveness more on a cool morning on the 10 miles to the station compared to the warmer drive home in the evening than I do with fuel.
Totally depends on if a car is tuned to utilise higher octane fuel.
In a standard 1.6 it would be a waste, in a ST, RS or a 5.0 Mustang then it makes sense.
Any car with a turbo is likely to benefit from using super fuel, although all petrol cars sold here have to be capable of running on standard 95 octane which is the normal fuel in this country.
When motor manufacturers do the mandatory fuel test I wonder if they use super fuels to boost their test results.
Thanks everyone for all your replies, sorry wasnt back sooner, been on holiday.
Throughout my holiday, I solely ran the car on Tesco Momentum and my car HATES it. Did 3 fill ups on the stuff (Yes was driving all over the shop) Noticed that on a cold engine start, the car would hesitate and struggle/jerk when accelerating, but as soon as the engine warmed up it was fine. However noting that, I did get a lot of increased range out of the amount of fuel I put in (a full tank would read 420 miles as opposed to cheap fuel reading 380 miles) My MPG was 33.5.
However even with only just 2 fill ups with a local near enough Sainsburys that I found selling premium with what I believe is 97 octane instead of the 99 Tescos stuff, my car runs much better on cold starting, this stutter/jerk when trying to accelerate has stopped but mpg has dropped by as much as 0.1mpg :laugh: I have heard that this is really BP ultimate because its Sainsburys and that they had a deal with BP?? If so, thats good because as per my previous posts, my local BP charges almost £1.40 p/l for ultimate.
On a side note, what would cause this stutter/jerkyness? BUT this could be a skewed result because I've just had the car in for service where they changed the oi/, oil filter and the air filter.
Unless the air filter was really badly clogged up I can't see that having any effect. I don't see how oil and filter could affect it at all.
