Bifftastic
Help with SYNC Bluetooth issues
Hi there. I'm new to the forum having just got my first Ford (Fiesta ecotech) and was wondering if anyone could help me.
First time I connected my phone to SYNC via bluetooth it worked fine. Downloaded my phone contacts etc. Played music fine. As I got into the car the phone would connect and the music would start to play.
Recently it will only play music from my phone if I connect via USB. bluetooth is still connecting but no music will play using this method.
Any help would be much appreciated.
Ta
I've reset SYNC from the menu. Told my phone to forget SYNC as a connection and re-paired them. No joy. Didn't know about the fuse option though.
The fuse is always a good option, it is like turning your computer off and on again lol. Also, check in your phone options that 'media' is still active when the phone is connected. You can check this on the phone and sync unit.
1 hour ago, Bifftastic said:
Thanks. Where will I find the fuse?
Behind passenger glovebox, look in the manual.
its number 24, it’s a 10A fuse on the far right near the repeaters. The manual is your friend here.
remove it for like 5 seconds, put it back in, start car up and you’re ready to roll
