Came home from work just about to get changed to go out to eddie rockets rob your pockets with the other half but upon further investigation of the letterbox i had noticed that the stainless steel blank + gasket for blanking the egr had come in the post...so me being me (Any excuse to work on the car) I pulled out the tool box and fitted it.
I'm no mechanic (just an electrician by trade) so I didn't really know what I was doing, i just about know a few odd things about cars so I kinda winged this instal because I couldn't find a tutorial to do this on my car.( probably is a few but wasn't arsed looking any longer)
Now it makes it easier if you take off the scuttle panel but I think you have to take your bleeden wiper arms off and all and I hadn't got time for that as the missus was waiting.
First thing I did was locate the egr valve, it's located behind the fuel filter. I took the 3x 8mm bolts off the black bracket that holds the filter in place. Then i removed the filter assembly and shoved it to the back of the engine bay ( fully intact)
Second thing I did was take the bracket that the filter sits in to that bolts on to the side of the engine off so I could have the room to slide the blank and gasket in to place. There is another 3x 8mm bolts holding in place
And last but not least I undone the two bolts on the valve just enough ( about 5mm) to get the gasket and the blank in to place. These are also 8mm
Then put back together.
Gonna try add all the pictures I have to this post. You will know what I'm talking about when you see the pictures.
This is not a massively detailed tutorial as I ain't got time for that but it's enough so that you'll have half of an idea of what to do.
The picture with the red circle is where you slide your blank plate in.
Total cost =10.50 time= 30 mins.( not including scrubbing the hands haha)
