JDM99 Posted August 26, 2017 Share Posted August 26, 2017 Hi Guys, Hoping for a bit of help. About an hour ago I got into my car and drove it for about 5 minutes. I have just tried to start my car up in order to get home however it's not starting, none of the electrics work, and it won't lock via the remote key. I managed to unlock via the key at first but now nothing seems to work. Has anyone ever came accross this before or have any advice on how to get my car started again? Kind regards Jack Quote Link to comment Share on other sites More sharing options...
griffithsbilly86 Posted August 26, 2017 Share Posted August 26, 2017 Have you checked your fuses maybe one has popped Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted August 26, 2017 Share Posted August 26, 2017 Might sound dumb, but I take it you've made sure the battery works and no fuses have popped? Otherwise you might be looking at faulty key chips or a replacement ecu. 1 Quote Link to comment Share on other sites More sharing options...
JDM99 Posted August 26, 2017 Author Share Posted August 26, 2017 Thanks for the replies. I haven't got anything on me to check the battery. I looked at the connections because thought it may have been a loose connection but all seems fine. Is there anything I should look out for to see if one of the fuses has popped?? 43 minutes ago, griffithsbilly86 said: Have you checked your fuses maybe one has popped Sent from my iPhone using Tapatalk 41 minutes ago, Luke4efc said: Might sound dumb, but I take it you've made sure the battery works and no fuses have popped? Otherwise you might be looking at faulty key chips or a replacement ecu. Quote Link to comment Share on other sites More sharing options...
griffithsbilly86 Posted August 27, 2017 Share Posted August 27, 2017 Pull every fuse out one by one to see if it's blown if not put back and try the next one Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted August 27, 2017 Share Posted August 27, 2017 Also remember you have 2 fuse boxes, one behind the glovebox and the other in the engine bay. 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted August 27, 2017 Share Posted August 27, 2017 when you say none of the electrics work, no dashboard lights, indicators, brake lights, interior light, side lights? could it just be as simple as the battery is dead? 2 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted August 27, 2017 Share Posted August 27, 2017 1 hour ago, isetta said: when you say none of the electrics work, no dashboard lights, indicators, brake lights, interior light, side lights? could it just be as simple as the battery is dead? That's what I'd have gone with at first. I'd have thought you got some sort of response on the dash though if the car had been drove an hour earlier. Then again, to assume makes an ***** out of u and me. 1 Quote Link to comment Share on other sites More sharing options...
jsk Posted August 27, 2017 Share Posted August 27, 2017 Same thing happened to my daughter. Did some shoipping came back to the car everything dead. battery had failed. No indications that it was on the way out just died. 1 Quote Link to comment Share on other sites More sharing options...
JDM99 Posted August 29, 2017 Author Share Posted August 29, 2017 Managed to get it jump started the next day and drove it down to Halfords to get a new battery as done all the above and all was fine so assumed it would've been the battery. Got a new battery and got them to do a battery check turns out it's the alternator that's gone and not charging the battery as I drive along. Gonna go scrap yard and buy a second hand one for £40 then fit it myself. Do you guys have any tips to help out or anything I should be aware of before I take the old one out? Cheers and much appreciate all your help. Jack Quote Link to comment Share on other sites More sharing options...
JDM99 Posted August 29, 2017 Author Share Posted August 29, 2017 On 27/08/2017 at 10:42 AM, isetta said: when you say none of the electrics work, no dashboard lights, indicators, brake lights, interior light, side lights? could it just be as simple as the battery is dead? On 27/08/2017 at 11:49 AM, Luke4efc said: That's what I'd have gone with at first. I'd have thought you got some sort of response on the dash though if the car had been drove an hour earlier. Then again, to assume makes an ***** out of u and me. Sorry for the late reply. There was literally nothing at all no dashboard lights or any signs of life in the car Quote Link to comment Share on other sites More sharing options...
