iVannity Posted August 27, 2017 Share Posted August 27, 2017 Focus Titanium x 2012 tdci keyless Hello, I have recently been having battery issues with my ford for the past week, after a jump start and taking it to a garage it seems the battery and alternator were in working order, (waiting for it to happen again to see if it was a battery drain somewhere). After a few days it has happened again, checking online I have disabled the bluetooth amongst other things until I can take it to a garage and check what is wrong with it. (Sunday today) Since my last jump (an hour prior to this post) to get the car up and running, there is a constant chime when I turn the car on, the sound you get when your door is open, this sound is continuous and won't stop and is very loud from the instrument panel. I have checked all the doors, boot, front, disabled auto headlights, turned of radio anything that would trigger the chime, though it is constant and won't stop. No warnings are on the panel, though when I did jump the car, it was spouting errors about headlamps, the ford key not being in the car, tyre pressures etc... which I think were related to the battery draining out. These warnings/errors are now gone, but the chime is still present 24/7 when the car is on/button is pressed, up until the car is switched off, it is extremally annoying and distracting. Any help, thanks! Quote Link to comment Share on other sites More sharing options...
iVannity Posted August 27, 2017 Author Share Posted August 27, 2017 Video of sound @ https://streamable.com/s1py9 All doors have been checked, boot, bonnet, no warnings at all, everything is normal. This only happened the second time I had jump started the car as it seems a battery drain is going on somewhere, will check with the dealer tomo. The sound gets overwritten i.e. if my seatbelt is not on, another sounding chime for that specific scenario will sound, then it will return to the chime in the above video, and back until I put my seatbelt on. It is ongoing until the car is turned off. Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted August 28, 2017 Share Posted August 28, 2017 Is this an automatic start stop car? Jump starting may have upset the intelligent charging system, and I would advise that you do not jump start again. Have you tried a new battery? Quote Link to comment Share on other sites More sharing options...
Delboy777 Posted August 28, 2017 Share Posted August 28, 2017 Try removing the battery lead for 30 mins then re connect, it might work. Quote Link to comment Share on other sites More sharing options...
iantt Posted August 28, 2017 Share Posted August 28, 2017 could be issues with your body control modue. as delboy mentioned, disconnevt battery for a short while then reconncect. also i would disconnect all the connectors on the bcm , checking connectors for any corrosion/water ingress. Quote Link to comment Share on other sites More sharing options...
iVannity Posted September 2, 2017 Author Share Posted September 2, 2017 Thank you for the help and replies! The issue has been fixed (will update if things change), though I am posting if others run into the same issue. The car is not stop-start, thank you for the feedback. I took it for a spin earlier in the week during the morning to drop my sister from work, whilst manging with the constant chime, the round trip took 30 minutes, by the time I had got into the car the same morning around 2 hours later, the chime has gone. As for the battery issue, I had taken it to the garage, they took it apart to see if they could find lodged water, circuit damage or anything out the blue, but all was clear, after turning the battery off for a while the problem still occured. In the end they changed the battery and all seems to be working so far fingers crossed. This is weird since another person said the battery was fine earlier on in the week. Will update if things change. Since i am on the forum and got feedback quick I was wondering if I should create another thread about an issue I have with the keyless door entry, a few months prior to the battery issue, i cannot unlock the door using the keyless function (changed the batteries, and cleaned the door handles) although I can lock the door by placing my thumb on the black pad. So whilst I can lock the door with the keyless entry, i cannot open them, any ideas guys before i delve into the unknown again. Thank you! Quote Link to comment Share on other sites More sharing options...
iVannity Posted September 5, 2017 Author Share Posted September 5, 2017 So i have the same problem again with the cars battery being drained, I called out the AA to get some numbers and it seems I have 1amp of battery power going out when the car is off. Anyone had any similar problems, he did mention the alternator and the new battery are in working order, so it seems I will have to trial and error to find the problem via the fuses? Since I don’t have the equipment it seems I will have to send it to the garage and forward the information unless anyone else has had any problems similar so I can try them at home, I have double checked the lights are off when the vehicle is off, from boots to glove box and all seems in working order. It does seem weird, is 1 amp enough to drain the car from starting, to not starting within 15 - 20 hours of it being switched off? Would appreciate some help, many thanks! Quote Link to comment Share on other sites More sharing options...
madmole Posted September 7, 2017 Share Posted September 7, 2017 AA man probably doesn't know that the focus doesn't immediately shut down when you turn off the engine, but slowly kicks off different systems in stages over the next 20-40 mins. I would expect it to be taking a fairly high draw immediately after shutting down The other issue is the moment you get near it it will sense the fobs proximity and start turning systems back on in readiness to start up. You will need to shut it down with the bonnet up and after an hour or so go measure the drain with the keys nowhere near it to get a true reading 2 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted September 7, 2017 Share Posted September 7, 2017 Even if it was drawing a solid 1amp the whole time, I think the smallest capacity silver calcium battery ford do is a 43ah (amp-hours).This means that the battery can provide a 1amp draw for 43 hours from fully charged to fully depleted (or any combination thereof, 43 amps for 1 hour for example or 10 amps for 4 hours 20 minutes).Though you should never really discharge an electrolyte battery below 50% if you can help it.Sent from my SM-G920F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
iVannity Posted September 11, 2017 Author Share Posted September 11, 2017 Thank you all for the information, I have tried too keep the battery from going flat, although sometimes it is inevitable with me not having access to the car for a large amount of hours sometimes. What is the best method of keeping the cars battery charged outside of starter kits? I had a feeling the amp draw would be higher due to the car trying to go into sleep mode, and other factors. I will leave the hood open and check the amp draw with the clamp meter I have brought after a period of time without the keys near me. Last question what is the best method of checking the fuses without disturbing the car which requires the opening of doors to the passengers fuse box and boot fuse box? As opening the doors activates multiple systems to kick in ? Thank you for the feedback it is definitely a parasitic drain. Posted from S8. Quote Link to comment Share on other sites More sharing options...
