lloydyyy Posted December 11, 2017 Author Share Posted December 11, 2017 Thanks. Seems more expensive than the part I posted. I'll see if I can source just the lock control cable rather than the control cable and door latch otherwise it makes sense for me to buy the cable and latch for £20 rather than £30 for just a new cable. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted December 11, 2017 Share Posted December 11, 2017 1 minute ago, lloydyyy said: Thanks. Seems more expensive than the part I posted. I'll see if I can source just the lock control cable rather than the control cable and door latch otherwise it makes sense for me to buy the cable and latch for £20 rather than £30 for just a new cable. Yeah, the link was more to show it was separate and the part number really, I agree getting a used one will be much cheaper, plenty of Mk6s in scrap yards as well. 1 Quote Link to comment Share on other sites More sharing options...
Fiesta1.25 Posted December 11, 2017 Share Posted December 11, 2017 That’s the whole assembly mate...... sounds like you just need the little clip on the end, check your broken one and see if it’s possible to separate it from the latch wire, if you can save yourself £19.95 and get one for a couple of quid from the scrappies [emoji106] Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted December 11, 2017 Author Share Posted December 11, 2017 55 minutes ago, Fiesta1.25 said: That’s the whole assembly mate...... sounds like you just need the little clip on the end, check your broken one and see if it’s possible to separate it from the latch wire, if you can save yourself £19.95 and get one for a couple of quid from the scrappies I can definitely separate the broken one from the latch wire. I've contacted the breakers yard where I had my new regulator and inner door card from. Hopefully the guy can help. He knows the part and has asked for a photo. Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted December 13, 2017 Author Share Posted December 13, 2017 The breakers yard I bought my other parts from can supply the end part for £10 posted. I've contacted a few other yards on eBay; one got back to me and quoted £15 including P+P. Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 4, 2018 Author Share Posted February 4, 2018 Finally managed to get around to fitting the new door card and regulator. I tested the window tonight and the regulator seemed a little slow to put the window back up. Not sure if it's just me. Here's a link to the video of the window being tested: https://drive.google.com/open?id=1HLkTvro7mpVl8waUYaCpoJWnB69lP9Lu Edit: I turned the engine on and tested the window again - seems to have made a difference. What do you think? I thought it might have been sticking a little on the way back up: https://drive.google.com/open?id=1BNl2-QbLKw37VcZ7r5nJbIwfvdD4R3LE 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted February 5, 2018 Share Posted February 5, 2018 14 hours ago, lloydyyy said: Finally managed to get around to fitting the new door card and regulator. I tested the window tonight and the regulator seemed a little slow to put the window back up. Not sure if it's just me. Here's a link to the video of the window being tested: https://drive.google.com/open?id=1HLkTvro7mpVl8waUYaCpoJWnB69lP9Lu Edit: I turned the engine on and tested the window again - seems to have made a difference. What do you think? I thought it might have been sticking a little on the way back up: https://drive.google.com/open?id=1BNl2-QbLKw37VcZ7r5nJbIwfvdD4R3LE I'm planning today of changing the door regulator on my mk6.5 fiesta. Hopefully might take pics of it. Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 5, 2018 Author Share Posted February 5, 2018 3 hours ago, zain611 said: I'm planning today of changing the door regulator on my mk6.5 fiesta. Hopefully might take pics of it. Best of luck. Let me know if you need any advice. I'll need to take the door card off again as it isn't sitting flush and there appears to be something pushing against the glass - I think it's a wire from the door loom pushing the back of the door locking mechanism and part of it is touching the glass. Would be grateful for advice from members if my window seems slow to go back up. 1 Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 11, 2018 Author Share Posted February 11, 2018 I stripped the door back down today and found the problem. The window was mostly between the rubbers but had pinched part of the rubbers towards the bottom, so it wasn't aligned between the rubbers perfectly. All back together now and working perfectly! So glad it's all done. I'll strip the driver's side down soon - I wasn't happy with the quality of the work by a local garage; the mechanic obviously didn't align the door card up and thus snapped most of the clips. And whenever I close the door with the window down, there's a loud rattle (as if the regulator is rattling). I might as well strip it back down and see what's going on. If anyone gets stuck with the same job, just give me a shout. Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 12, 2018 Author Share Posted February 12, 2018 I noticed a problem with the door locking earlier. When I lock the car, the passenger door lock makes a rapid clicking noise and the interior handle doesn't move in. Although the car locks fine and the door opens fine. The lock didn't make a rapid clicking noise when the latch cable wasn't connected to the door handle, i.e. when the outer door card had been removed. Any ideas? Quote Link to comment Share on other sites More sharing options...
zain611 Posted February 12, 2018 Share Posted February 12, 2018 1 hour ago, lloydyyy said: I noticed a problem with the door locking earlier. When I lock the car, the passenger door lock makes a rapid clicking noise and the interior handle doesn't move in. Although the car locks fine and the door opens fine. The lock didn't make a rapid clicking noise when the latch cable wasn't connected to the door handle, i.e. when the outer door card had been removed. Any ideas? Are you talking about it making several clicking noises rapidly when you press the lock button? My fiesta has done the same thing since I've bought it and haven't had a problem with it. Sometimes it just makes a single click sound. I also did the regulator today. You can see what went wrong with the other one. Someone also tried putting grease on it Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 12, 2018 Author Share Posted February 12, 2018 My passenger side lock hasn't made this noise before. It sounds as if something is jamming - that sort of rapid, repeated clicking noise. I think I'll have to strip it back down and take another look. Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 13, 2018 Author Share Posted February 13, 2018 I found the problem and fixed it, but I'm not sure how When I disconnected the latch cable from the door handle and opened/locked the doors, the lock seemed to work fine and without making that strange noise. But when I held the latch cable and clip on its side to simulate it being attached to the door handle, the lock made that strange noise when I locked the door. Here's a video clip to demonstrate what I mean: https://drive.google.com/open?id=1lTYjkz_4h-kI-rf-s-pxrMgVyIuJVtNR After twisting the cable clockwise and anti-clockwise several times to see if tension in the cable was causing the problem, I began to think the lock was knackered. But then after several tries and at the last moment, it seemed to work fine with the door handle attached - weird. But before the lock started working fine again, I started to unscrew the screws on the inside edge of the door to get the locking mechanism out, but one of the screws wouldn't budge (even with WD40) and I've stripped the thread. I might buy a new screw on eBay but I've no idea how to get the old one out! And in a bit of panic trying to strip the door down, I snapped one of the hooking lugs on the back of the inner door card - not sure if this would matter because the door card still attaches fine but is it worth buying another one for the sake of a few pounds? Quote Link to comment Share on other sites More sharing options...
zain611 Posted February 13, 2018 Share Posted February 13, 2018 That's the exact same rapid clicking I get. Sometimes I just clicks twice. Quote Link to comment Share on other sites More sharing options...
lloydyyy Posted February 13, 2018 Author Share Posted February 13, 2018 1 hour ago, zain611 said: That's the exact same rapid clicking I get. Sometimes I just clicks twice. Mine's never done it, so I began to worry when it started to happen after I put the outer door card back on. Can't believe I snapped one of the lug hooks on the back of the inner door card and rounded off a screw for the door lock screw Question is - how on earth do I get the damn thing out now? I'd like to replace it if I can. Edit: Panic over. The screw looked totally rounded-off but a larger Torx bit managed to fit. I found a magnetic bit holder for my Dewalt screwdriver, so just inserted the Torx head and went at it. It came off after a bit of force, so it was well and truly stuck! Phew. Has anyone got a spare screw I could buy? Quote Link to comment Share on other sites More sharing options...
Pacc Posted August 16, 2019 Share Posted August 16, 2019 Can anyone put me on to a wind up pass side window regulator for a 3 door 54 plate fiesta plz .. Quote Link to comment Share on other sites More sharing options...
Bennyboy Posted December 4, 2019 Share Posted December 4, 2019 Does anybody know what the white clips that hold the window called and where can I get them from Quote Link to comment Share on other sites More sharing options...
Crazymark Posted August 8, 2020 Share Posted August 8, 2020 Hi my cables has gone got replace ment cables for it can not figure out for the life of me how they go round the cog bit where the window motor sit and if someone can put pic of cables in place be great pls help lol Quote Link to comment Share on other sites More sharing options...
Darthstumpy Posted September 22, 2020 Share Posted September 22, 2020 Hi Was wandering if anyone can help, I have replaced my manual widow regulator on my mk6 but managed to lose the 3 screws that hold the handle winder in place to the door . Any ideas what size I need ? Thank you Quote Link to comment Share on other sites More sharing options...
