mustang86 Posted September 6, 2017 Share Posted September 6, 2017 Hi everyone. Just a quick question. What does the service oil warning mean? The car isn't due a service for another 2500 miles and it has the right amount of oil.. it's a 2011 kuga and the warning comes on when starting the engine then goes straight off 🤔 Thanks in advance 😊 Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted September 6, 2017 Share Posted September 6, 2017 Chances are it has not been reset on the last service, not sure of the reset procedure but, put key in ignition fully press down on both the accelerator and brake turn key to pos 2 (one before you fire it up) wait 10 ish seconds and a message should come up saying reset. If pressing the accelerator and brake doesn't work try clutch and brake. Make sure all doors are closed when doing this or it won't work. Quote Link to comment Share on other sites More sharing options...
mustang86 Posted September 6, 2017 Author Share Posted September 6, 2017 22 minutes ago, Ryan_Tango said: Chances are it has not been reset on the last service, not sure of the reset procedure but, put key in ignition fully press down on both the accelerator and brake turn key to pos 2 (one before you fire it up) wait 10 ish seconds and a message should come up saying reset. If pressing the accelerator and brake doesn't work try clutch and brake. Make sure all doors are closed when doing this or it won't work. Unfortunately the Kuga has a push button start.. Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted September 6, 2017 Share Posted September 6, 2017 I found this online Turn off the ignition Close all doors. press and hold the Start button for two seconds without touching the brake pedal. Next, simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 20 seconds, until a “Service: oil reset in prog.” message shows on the instrument cluster display. Continue holding the accelerator and brake pedals until the display says “Service: oil reset complete”. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed. Hope that helps :) 3 Quote Link to comment Share on other sites More sharing options...
mustang86 Posted September 6, 2017 Author Share Posted September 6, 2017 4 hours ago, Ryan_Tango said: I found this online Turn off the ignition Close all doors. press and hold the Start button for two seconds without touching the brake pedal. Next, simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 20 seconds, until a “Service: Oil reset in prog.” message shows on the instrument cluster display. Continue holding the accelerator and brake pedals until the display says “Service: Oil reset complete”. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed. Hope that helps :) Nice one thank you. Will give it a go when I get home at the weekend 😁 1 Quote Link to comment Share on other sites More sharing options...
mustang86 Posted September 10, 2017 Author Share Posted September 10, 2017 On 06/09/2017 at 9:40 AM, Ryan_Tango said: I found this online Turn off the ignition Close all doors. press and hold the Start button for two seconds without touching the brake pedal. Next, simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 20 seconds, until a “Service: Oil reset in prog.” message shows on the instrument cluster display. Continue holding the accelerator and brake pedals until the display says “Service: Oil reset complete”. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed. Hope that helps Thanks dude. It's worked 😁 Quote Link to comment Share on other sites More sharing options...
