Ford S-max 2.0 zetec tdci powershift 140 Enngine Malfunction warning, Ì warning and extremely slow throttle response from stop position
Extrovert
 Share
Just connected purple with green line together using a small length of wire and horn is now working.  I am going to connect the grey one too. Will report back soon.
Link to comment
  • Replies 58
  • Extrovert
    31
  • iantt
    27
  • Ryan_Tango
    1
Connected the grey wire with purple line using a short length of wire.  No difference in the pedal and engine malfunction light is still on as well as throttle position sensor error on obd2. Shall i leave them connected?
Horn relay is gone now.  It will be interesting to know what the grey wire with purple line is for. Returned both pedals and the one with md code ordered.  Any suggestions to check wiring/fuses.
Thank you very much for your support Ian,  there is no way I would have been able to sort out the horn problem without your support.
Link to comment
I will report back about me pedal.  It will be next weekend though.
Link to comment
Brake fluid,  that explains why the warning light (exclamation mark in brackets) disappeared since i connected the broken wire.
Link to comment
Ian, I replaced the pedal with md code but still no difference.  Engine malfunction warning is still on and obd sensor still shiw the same error codes. Any suggestions?
Link to comment
It's driving me insane.  The only option is to order the pedal from dealers and try. However,  if it doesn't fix the issue, it's a waste of £85.
Could there be something wrong with throttle body or the sensor attached to it?  Any electric/cables I can check?
Link to comment
i will check wiring diagrams later and get back to you with wiring checks. make a note of the wiring colours at the pedal connector. then you can use multimeter to check all the wires
Link to comment
  • 4 weeks later...
Hi
Can someone please recommend a ford specialist near Huddersfield or Manchester FOR THE above issue please?
Having spoken to one local ford specialist I was directed towards dealers and potentially faulty ecu based on verbal description.
Second autoshop suggested blocked dpf or blocked egr after briefly assessing the car without actual assessment.
Another forum suggested replacement of throttle body.
I think the issue is above my understanding and needs to be looked at by someone who know what they are doing.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
