Meikle
2.2 TXS flat spot
Had my 2.2 Titanium Sport now for around 3 months & finding a flat spot when taking off in 1st gear also the gear changes are not as smooth as I would like, is there maybe a filter etc needing cleaned/replaced?
Any input much appreciated
Well, no filter to change then. Clutch issues?
Do you know if your car has had the PCM update from Ford? It solves a massive turbo lag issue which may help with changing gear process. My car used to bog down badly when trying to pull out of junctions, so bad that it was dangerous. Or stall when trying to park (slow manoeuvres).
