Evening all,
If I use the drivers window control to operate the passenger window it lowers as normal when I press the switch to lower but also lowers when I press the switch to raise the window.
If I use the passenger window control it works fine.
Any ideas?
Cheers,
Milly
Sounds like the physical switch on the driver's side is damaged.
Either that or the loom to it has been pinched or damaged.
If you have one touch up and down windows you could try resetting the window memory but I think it may not work in your case.
Wind a window all the way down then press down again and hold for 3 seconds. Then wind up and press up again and hold for 3 seconds. Repeat for each window.
Good luck!
