AdBlock Warning
Curious if anyone has any experience with Eibach lowering springs which can be purchased from Ford, part no: 1569225.
I know they only drop the car 30mm but what I want to know is if these can be fitted to the standard dampers and if it will have any impact on suspension performance, ie. Bottoming out and potential damage to the dampers.
I'd imagine coming recommended from ford it would have been stated if there was a requirement for different dampers.
Ah! You're right. I'm pretty sure I was told at the time of buying it is 15mm lowered as standard so the springs would effectively only drop it another 15mm, which for nearly  £200 ain't really worth it 🤔
