Fuel Injectors Defective
CK1
 Share
So was leaving my work car park recently and evenings are getting a little colder. Turned on the car and was in a queue when I felt the car shuddering a little when in idle. I was leaving car in next day for a winter health check with my Ford dealer  and mentioned this.  To my complete shock I have been told I have 3 out of 4 fuel injectors defective, and they recommend I change them asap. The cost is massive £155+VAT and labour each in fact should do all 4 I was told. Does this sound correct? Very sudden with not many symptoms, and am wondering if they are just trying it on!!! Advise would be appreciated. I would have thought with such a large cost issue there would have been error codes, more symptoms etc.....
Link to comment
Definitely get a 2nd or 3rd opinion. There are quite a few possible causes of uneven running.
Also ask how they diagnosed it. It may just be cylinder balance readings from a diagnostic system (which you can do for yourself using Forscan or some other good system), if so it is still not definite.
Leak-off tests, or removal of injectors for a proper test are the best ways. But these are time consuming. I doubt if the garage did anything like that.
Injector problems usually take some time to develop, and a little shuddering is unlikely to do any lasting damage, especially at low throttle openings, so do not be rushed into anything, unless you feel confident they know what they are talking about.
Link to comment
Thanks for you advise peter, have it booked into a different garage next week. Will quote some of this info....
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
