Postie123
Sub woofer
Hi hoping someone has done this or knows how this fits as there is no RCA inputs. Is it a case of cutting in existing speaker wires?
Hi, i have this underseat fitted.
Yunii
Sent from my SM-G925F using Tapatalk
You would needvsomething like this to get sound from your headunit. Also you will need direct live feed from battery with fuse. & earth from say your seat bolt.
Could I use that rca converter with the pioneer amp/sub? Is it easy to wire up?
I believe so. A little know how to solder. & where to route the feed from. The kit will or should give you instructions.
Btw as well as the live & earth you also their is another wire which is like a remote so when you switch car & radio it comes on. & dont drain battery
Yunii
Sounds easy enough to do and like you say there should be instructions.
Thanks for your help mate.
No worries, i also upgraded my stock Speakers & tweeters to fusion components but running the ford sony dab 6cd unit. You would need to wire to rear Speakers.
Sorry i couldnt explain detailly as did this few years ago.
Yunii
