zetec Adam
Yellow headlight tint
Yeah you can have yellow at the front.  Yellow fogs look good and are pretty common.  Personally wouldn't do the headlights though, the light output will be reduced, it's not actually illegal though.
Sorry but I....[baaaawwwk]...don't feel very...[baaaawwwk]...well, I maybe ate...[baaaawwwk]...something funny...[baaaawwwk]...
If an MOT tester was in a rubbish mood when checking the car then it could get a fail, same goes for a road traffic bobby, they could give you a hard time. I've been told, so can't claim this to be % true that your headlights must remain the same colour as they left the factory. So white to stay white and red to stay red. My brake light flashes with my indicator, so if I'm indicating right my right brake light also flashes. The left brake light and high level brake light remain steady and vice versa, not sure of the legalities. Clive, what is the law on this?
Flashing brake lights are an MoT fail.
Do they do this on purpose or do you have a fault?
If it's a fault then probably an earthing error in the tail light cluster.
If on purpose did you fit a module to cause it?
I know some cars come with flashing brake lights from factory but only activate under heavy braking (a la emergency stop). I believe some BMW models do this but as this is EU type approved it supercedes any UK laws.
There is no fault, you can code it using Forscan. It's the setting for the US Fusion. It actually makes the indication more visible. I plan to change it back to standard though, I only modified the block to see it if it would activate a sequential type flash.
I wasn't sure if the brake lights on the Mk5 Mondeo flash under heavy braking, I know the hazard warning lights flsah
My friend has a Mini Clubman (essentially a BMW that goes to Slimming World) and his brake lights flash under 'emergency braking' - I think this is activated when the ABS is or when speed drops a large amount in a short space of time.
Best description of a Clubman I've ever heard!
Sent from my Phantom6 using Tapatalk
I've seen a motorbike with a flashing brake light, made it more obvious it was braking. Obviously an aftermarket addition and illegal though.
It does make it much easier to see that 'something' is going on but what? Your first thought would be that it was an indicator not a brake light.
Sent from my SM-G935F using Tapatalk
