Nath87
Mk7 fiesta wheels on a Mk5 Fiesta
Refresh my memory, does the Mk5 axle have a four bolt layout for the wheels? If it does they should fit on, I would just check for the fitment with regards to the clearance of the wheel from the arch and width of the wheel, last thing you want is the wheel being too wide and rubbing off the arch when trying to turn a corner. You should be able to compare the dimensions between a Mk7/Mk8 Fiesta ST wheel and your own wheel to find out the answer.
Hope this helps :)
