Nath87 Posted September 25, 2017 Share Posted September 25, 2017 Will these wheels fit on my mk5 does anyone know? Quote Link to comment Share on other sites More sharing options...
fiestamadaaron Posted September 26, 2017 Share Posted September 26, 2017 Hi, Refresh my memory, does the Mk5 axle have a four bolt layout for the wheels? If it does they should fit on, I would just check for the fitment with regards to the clearance of the wheel from the arch and width of the wheel, last thing you want is the wheel being too wide and rubbing off the arch when trying to turn a corner. You should be able to compare the dimensions between a Mk7/Mk8 Fiesta ST wheel and your own wheel to find out the answer. Hope this helps :) Quote Link to comment Share on other sites More sharing options...
Nath87 Posted October 2, 2017 Author Share Posted October 2, 2017 Mk's are 4stud for the wheels yeah. Quote Link to comment Share on other sites More sharing options...
fiestamadaaron Posted October 3, 2017 Share Posted October 3, 2017 Then they should fit, just like I said make sure they don’t rub and you won’t have a bad time! Quote Link to comment Share on other sites More sharing options...
