Minder Posted September 30, 2017 Share Posted September 30, 2017 just bought a second street ka as a winter project and the heaters are blowing hot no matter what settings they are on want to sell the car next year around march and want the AC blowing cold dont want to sell it to anyone with the AC not working as it should be ice cold any help on this would be of a great help cheers mark Quote Link to comment Share on other sites More sharing options...
iantt Posted September 30, 2017 Share Posted September 30, 2017 2 causes, normally the heater control valve under the bonnet http://www.ebay.co.uk/itm/330561770165less common is the heater contol panel. Quote Link to comment Share on other sites More sharing options...
simonwill69 Posted September 30, 2017 Share Posted September 30, 2017 Thanks for your advice iantt , i have just bought a Streetka with similar symptoms (although mine's a 'keeper'). How may i tell the difference? The temp control knob on the heater control panel has very little or no hand resistance, if this a help. Regards, Simon Quote Link to comment Share on other sites More sharing options...
iantt Posted September 30, 2017 Share Posted September 30, 2017 to diagnose correctly you need a multimeter. check for 12v supply to the heater control valve, and check across the connector for s clock pulse voltage(basically 12v on and off repeating approx 18 times a minute with heater control set to mid temp. if it is pulsing then the control panel is ok and heater control valve is at fault Quote Link to comment Share on other sites More sharing options...
iantt Posted September 30, 2017 Share Posted September 30, 2017 90% of time its the valve. Quote Link to comment Share on other sites More sharing options...
simonwill69 Posted October 1, 2017 Share Posted October 1, 2017 Thanks Quote Link to comment Share on other sites More sharing options...
137699 Posted October 2, 2017 Share Posted October 2, 2017 Agreed. HCV - ours was the same - changed the valve, solved the problem. Quote Link to comment Share on other sites More sharing options...
