tommyukuk Posted October 7, 2017 Share Posted October 7, 2017 Hi, just wondering if i could get some advice, we've had our car a couple of years now with no problems till recently, our cruise control randomly cuts off after 10 minutes or so into a journey. If you start the car it will set straight away and stay set untill you finish the journey if it was say motorway travel. Normal travel it will set but after a couple of times changing gears etc it will turn off and not come back on again. If the car is stopped and turned off for around 10 minutes it will work again for a short period of time. Tried a bluetooth scanner that came up with P0704 - clutch switch input circuit malfunction. But I've no idea what to replace.. ideally I'd like to try do it myself if pos... 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 7, 2017 Share Posted October 7, 2017 sounds like the switch on the clutch pedal is naff easy to do disconnect the wiring then turn the switch to take it out Quote Link to comment Share on other sites More sharing options...
Tommo17 Posted October 7, 2017 Share Posted October 7, 2017 Dez a picture would say a 1000 words in this instance Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 7, 2017 Share Posted October 7, 2017 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted October 8, 2017 Share Posted October 8, 2017 The rare time a scanner code actually tells you exactly what's wrong! Good luck resolving and post back with your results if you feel inclined to! Quote Link to comment Share on other sites More sharing options...
tommyukuk Posted October 9, 2017 Author Share Posted October 9, 2017 Thank you for the replies, will have a look on eBay for a replacement and see how to get the old one off, had a quick look earlier and it nearly broke my back trying to get down there 😂 Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 9, 2017 Share Posted October 9, 2017 3 minutes ago, tommyukuk said: Thank you for the replies, will have a look on eBay for a replacement and see how to get the old one off, had a quick look earlier and it nearly broke my back trying to get down there 😂 its a bit tight lol Quote Link to comment Share on other sites More sharing options...
tommyukuk Posted October 9, 2017 Author Share Posted October 9, 2017 Ordered a new one earlier, just thought I'd try see if there were any new codes on, I seem to be getting a p12-6 powertrain, which doesn't show up on Google as a recognised code (for me) but sounds ***** expensive!!! Oh joy!! Quote Link to comment Share on other sites More sharing options...
