Deano2606 Posted October 8, 2017 Share Posted October 8, 2017 I took the dash out of my car after refitting it the car wont crank says engine fault with pats code 16 its the same dash only out 10 mins now cars dead Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted October 8, 2017 Share Posted October 8, 2017 I think if your car is a mk2 focus, you may have inadvertantly caused the dreaded common fault with them. If you can get a code reader on it it may confirm the theory. @Tdci-Peter has a great guide on fixing this yourself if you can use a soldering iron or @Xxnamxx could put you in touch with a guy on eBay who can repair for a reasonable sum as s/he has just had the same problem. I think it has something to do with bad solder joints on the main connector which just need reflowing, correct me if I'm wrong Peter. Good luck. Here's the post I meant. I think it has advice from Peter on it http://www.fordownersclub.com/forums/topic/96200-car-wont-crank/ 2 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted October 8, 2017 Share Posted October 8, 2017 2 hours ago, Deano2606 said: I took the dash out of my car after refitting it the car wont crank says engine fault with pats code 16 It might be useful to know why the dash (IC) was removed! However, the 2006 IC is rather notorious for bad solder connections to the main connector. So removing it may have disturbed the weak solder connections. It is the though hole soldering from the pcb to the connector that seems to be the most vulnerable bit. You can check the connections with a multimeter, or measure the resistance between the CAN bus lines, using pins 6-14 in the diagnostic connector. This should be 60 ohms, it will read about 120 ohms if the solder joint to the connector has failed. This certainly will give PATS code 16, amongst other symptoms. 1 Quote Link to comment Share on other sites More sharing options...
Deano2606 Posted October 16, 2017 Author Share Posted October 16, 2017 Had two mechanics out cant get reading from obd port rac told me to take to ford to find problem told him cheaper to buy another car Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted October 16, 2017 Share Posted October 16, 2017 45 minutes ago, Deano2606 said: cant get reading from obd port The OBD port uses the same pair of wires (the HS-CAN bus) as the PCM & IC use to communicate. There is also 12v and ground, with a fuse (F46 or F107 in later cars) for the 12v. But if the 12v & ground are ok, it must be those HS-CAN wiring connections. Quote Link to comment Share on other sites More sharing options...
Xxnamxx Posted November 1, 2017 Share Posted November 1, 2017 If you still require a repair then i used a guy on eBay called dieselpumprepair2 had a quick turn around of under a week and he gives warranty (lifetime i think). Lots of other listings on eBay aswell if you want to try someone else. P.S It cost me £49.99, I think if he gets it and tests it but it shows as working then I think it is only £20 for the test. Quote Link to comment Share on other sites More sharing options...
