start problem and white smoke
9 replies to this topic
#1 mondeo79
mondeo79
    Member
  • New Member
  • PipPip
  • 15 posts
  • Ford Model: mk6 escort gti
Posted 18 January 2010 - 03:42 AM
hi there i hav 18td r reg which has a start problem from cold but when started it starts first turn after that also hav white smoke car runs ok.last onwer put kn filter on and played with the settings on it. does any 1 hav any ideas
Have something to contribute?
#2 GrahamH
GrahamH
  • New Member
  • 42 posts
  • Name: Graham
  • Ford Model: Mk3 Zetec dtci estate
  • Year: 2006
Posted 22 January 2010 - 04:53 PM
Sounds like Glowplugs, easy to check if you have an ohmeter.
#3 mondeo79
mondeo79
    Member
  • New Member
  • PipPip
  • 15 posts
Posted 22 January 2010 - 04:57 PM
hav new glowplugs in still the same cheers bud
#4 GrahamH
GrahamH
  • New Member
  • 42 posts
  • Name: Graham
  • Year: 2006
Posted 22 January 2010 - 05:13 PM
glowplug relay?
#5 mondeo79
mondeo79
    Member
  • New Member
  • PipPip
  • 15 posts
Posted 22 January 2010 - 11:23 PM
glowplug relay?
is that the 1 under the battery tray.and cheers mate
#6 stef123
stef123
  • Management
  • 5,751 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 23 January 2010 - 12:44 AM
if you suspect glow plugs, i would get a multimeter and check they are getting 12v, if they dont then i would start checking relays etc.
#7 mondeo79
mondeo79
    Member
  • New Member
  • PipPip
  • 15 posts
Posted 23 January 2010 - 02:01 AM
i had new glow plugs put on 2 months ago has new battery garage check it when plugs put on last owner messed with pump settings and put kn filter on trying new air intake and air mass flow meter aswell u can smell burnt diesel form exhaust think it is running 2 rich can u turn diesel pump down.
plus not much power going up hills not like last mondeo any ideas of lack of power.
#8 GrahamH
GrahamH
  • New Member
  • 42 posts
  • Name: Graham
  • Year: 2006
Posted 25 January 2010 - 01:56 PM
Sorry but don't know. Mine has PCM (power control module) behind o'side Macpherson strut., but expect your has relay.
#9 freda
freda
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: Ford mondeo Zetec TDDi
Posted 07 June 2010 - 04:24 PM
Hi
I am really interested to know if you got to the bottom of this, as it seems a common problem. I have exactly the same problem on a 2001 mk3 TDDi and as you say it appears to be fuel. I too started down the glow plug route, but i think these are new and it looks as if they are working OK. best wishes
tony
#10 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 07 June 2010 - 05:02 PM
it sounds like the previous owner has altered the pump timings to try and get more fuel into the system,get the pump timing checked.
Not what you're looking for?
