Dagger
Horn not working - MK1 Focus
Hi
My horn isn't working, when I press the steering wheel to activate it, I get a clicking noise near the glovebox, but no horn sound
Is it easy to replace the horn, as I assume it's broken
you need to get a voltmeter at the horn connectors, or you need to remove horn and get some wire and try it on the car battery.  At the moment you do not know if   a)horn itself faulty  or  b)power is not getting to horn (wire/fuse problem).  or it might just be corroded / dirty connector on the horn that needs some wd40 and a bit of a twiddle to make good connection.  Don't buy parts unless you know that's what is needed.
