Thelani Posted October 18, 2017 Share Posted October 18, 2017 The drivers seat belt sensor is going off at least once every minute, if I shuffle it goes off but seriously I can't disco for several hours on long distances. The seat belt is secure, it has passed a recent MOT but the fault has been ongoing for a few months now and with a 2 day drive looming I can't think of anything other than tooth ache that can be more irritating, please help? 2007 diesel S Max. Thank you in advance. Just in case anyone thinks it, I wear my seat belt and always will but still I need to stop the noise not because I want to be 'free' of the belt. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 Get the seat belt stalk replaced. That's where the micro switch is that detects the belt fastened. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 Or you could try disabling the chimes.Switch ign on , wait 15 seconds, then buckle and unbuckle driver's seatbelt 9 times within 60secs ending with belt unbuckled. Belt warning indicated should flash 3 times to confirm. Ign offIt may or may not work as the buckle switch is playing up 1 Quote Link to comment Share on other sites More sharing options...
Thelani Posted October 18, 2017 Author Share Posted October 18, 2017 Thank you iantt, I asked a local garage and after much head scratching they said they'd have to put it on the diagnostics and see which of several things it could be but to be warned it's labour intensive to hunt faults. I felt like I was being taken for fool so I thought I'd ask here before going to another garage. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 http://www.ebay.co.uk/itm/Genuine-Ford-Galaxy-WA6-S-Max-WA6-O-S-RH-Front-Seat-Belt-Buckle-1778750/272378818590?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D48478%26meid%3D67f9103827ab4b7c945c27ccd983ffcc%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D272378818590&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Ab84c9834-b420-11e7-a79f-74dbd180dc33%7Cparentrq%3A304c4ebc15f0a99481034684fffdfd94%7Ciid%3A1 if you check this link to eBay you will see the wiring for the seatbelt minder switch in the buckle/stalk. when you disco in your seat the belt buckle is twisting and giving temp connection putting light and sounder off. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 if buying new , i would check with seller or garage for the correct part number. the link is just an example. Quote Link to comment Share on other sites More sharing options...
Langers77 Posted November 29, 2017 Share Posted November 29, 2017 Thank you Ian TT - I didn't believe your 'buckle/unbuckl'e tip could work - but it did! No more intermittent clanging - but must remember to clip on my seatbelt! 1 Quote Link to comment Share on other sites More sharing options...
Langers77 Posted November 29, 2017 Share Posted November 29, 2017 Mondeo Mk3 & Mk 4 Ghias.pdfMondeo Mk3 & Mk 4 Ghias.pdfMondeo Mk3 & Mk 4 Ghias.pdfAs a 'Newbie' I should add that over the last 47 years I have owned 4 Cortina's, a Granada Ghia X and had 4 Company owned Mk 3 Mondeos and an 'S Max', 4 privately owned Mk 3's and now own a 2008 Mondeo Ghia TDCi - and driven well over 400,000 miles in Fords, had very few problems in what were/are generally high mileage cars and spent very little money on mechanical or electrical problems in all those years - you could say I am quite committed to the larger Fords! However, the best Mondeo I have ever owned was the Mk3 Ghia 'X' that was sadly written-off earlier this year and replaced with the Mk 4 Ghia that I did not realise had been 'down-specced' by Ford from the Mk3 Ghia - should have waited for a Titanium but none were available at the time I needed to replace the Mk3. Quote Link to comment Share on other sites More sharing options...
