Lovemyfester Posted October 21, 2017 Share Posted October 21, 2017 Hi all I have a 2006 Fiesta 1.25 durotec engine, and I noticed the oil was very low so I thought Il stick a bit in, well I did it cold, and after diping it seemed spot on the top line if the stick well pleased I dropped the bonnet and carried on with life (got married) anywho that was two weeks ago, I thought Il check it out just to make sure it was all still good in there yesterday, and it over the top line on the stick,not sure if the drive was a little slopy...or what but it's highter then the top knoch allso on the bendy bit just under when cold just up to it warm see pictures... Is it safe, or should I go and get it drained out! Bit worried! Quote Link to comment Share on other sites More sharing options...
Russ Posted October 21, 2017 Share Posted October 21, 2017 Are you positive the car is on level ground when you check the oil level and I’m assuming you’ve wiped the dipstick dry then dipped it again? Overfilling can be just as bad as too low an oil level, personally I’d leave it (but that’s just me) but if you wanted piece of mind you could easily slacken the sump plug a bit and let some oil drain out into a container then nip the plug back up and check the level again. 1 Quote Link to comment Share on other sites More sharing options...
Lovemyfester Posted October 21, 2017 Author Share Posted October 21, 2017 Thanks for the reply! Yeah I thought about leaving it as I don't do big miles so hopefully in time it will burn off, it's not running that bad!! Quote Link to comment Share on other sites More sharing options...
