jiosaeo Posted October 29, 2017 Share Posted October 29, 2017 hi am am new here but need help .....my blower has stopped working ...I have power to the switch so thought it was the switch and changed it ..one suggestion is feed 12volt to the blower direct BUT TO WHERE ON THE HEATER BLOWER ....Also I am told it may be my fuse box 94ag14a073baa.....any thoughts ....and where would I get a replacement fuse box if needed ....I know some fuseboxes are more prone to fail than others ....does anyone know if mine is on the list . Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 what model ford do you have and age? has blower stopped on all four positions ? Quote Link to comment Share on other sites More sharing options...
jiosaeo Posted October 29, 2017 Author Share Posted October 29, 2017 hi its escort mk5 //orion mk3 from 1993 ....nothing on the 3 position switch at all ....fuse ok ...stuck my head in both footwells but cant see wiring . Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 thats because the fan motor is under the bonnet just under the windscreen. Quote Link to comment Share on other sites More sharing options...
jiosaeo Posted October 29, 2017 Author Share Posted October 29, 2017 I shall look ...thanks Quote Link to comment Share on other sites More sharing options...
jiosaeo Posted October 29, 2017 Author Share Posted October 29, 2017 hi ian just looked ...its under a black plastic cover shelf ...how do you get access to it I can see that its a plastic removable cover un clipwires and bulkhead rubber strip ...I can see 4 bolts two at either end .IS THERE MORE there usually is Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 that sounds about right . theres 6 bolts. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 check for 12 volts at connector. position 1 will feed the black/red wire, position 2 black/yellow, position 3 black/ green. if nothing at any of them , then fuse box is your likely cause. if you have then motor. resistor pack should still allow 12 v to motor so i doubt that is your issue. Quote Link to comment Share on other sites More sharing options...
jiosaeo Posted October 29, 2017 Author Share Posted October 29, 2017 where are the other two bolts UNDER THE SOUNDPROOFING?? sorry but don't understand term ..... if you have then motor etc etc .....ALSO Is the resistor pack a separate item and how do you test that Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 Sorry, I should have written that better. If you have feeds to the connector , then it's likely the motor is faulty. The resistor pack is separate. To test it you can check resistance with multimeter set to ohms. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 The bolts , I will see if I can find a picture for you. Has been probably 12-14 years since I've looked/done the job. Quote Link to comment Share on other sites More sharing options...
jiosaeo Posted October 29, 2017 Author Share Posted October 29, 2017 hi ian ..many thanks ...its not urgent as the car is not being used for a fortnight due to my going abroad Tuesday for 12 days ..you have been very helpful ...one last thing ...if I need a fuse box do I need one with the exact same number as mine Quote Link to comment Share on other sites More sharing options...
jiosaeo Posted November 16, 2017 Author Share Posted November 16, 2017 finally fixed it after pulling all the plastic covering away ....removed the fan ,cleaned the connectors give it some WD 40 and all is working again BUT what a pain to get to 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted November 16, 2017 Share Posted November 16, 2017 good to hear you finally got it sorted. Quote Link to comment Share on other sites More sharing options...
