oldboy22 Posted November 15, 2017 Share Posted November 15, 2017 My window has just stuck down at the bottom When i press the up/down switch i can hear the motor.So is there anything i should be looking for inside the door that might help spot the problem thanks Quote Link to comment Share on other sites More sharing options...
isetta Posted November 15, 2017 Share Posted November 15, 2017 you will need to get the door card off and have a visual look at what has gone wrong, broken off, become disconnected, got jammed etc. Quote Link to comment Share on other sites More sharing options...
Ticktock Posted November 15, 2017 Share Posted November 15, 2017 Get the window motor out (easy job) and check the plastic cog on the spindle hasn't broke. That's what happened to mind, I'd stripped the whole door down before I found out. Quote Link to comment Share on other sites More sharing options...
oldboy22 Posted November 15, 2017 Author Share Posted November 15, 2017 52 minutes ago, Ticktock said: Get the window motor out (easy job) and check the plastic cog on the spindle hasn't broke. That's what happened to mind, I'd stripped the whole door down before I found out. Thanks so its easy enough to get in there Quote Link to comment Share on other sites More sharing options...
isetta Posted November 16, 2017 Share Posted November 16, 2017 "Thanks so its easy enough to get in there" , not really, you need to get the door card off without damaging anything. In the old days these things were pretty easy and obvious, now it's all hidden fixings and it's hard to know where to start from just visually looking at the door card. See if you can find a youtube video of it (I have not checked) Quote Link to comment Share on other sites More sharing options...
Chick1888 Posted November 16, 2017 Share Posted November 16, 2017 there is a few videos on youtube of how to remove the door skin etc... Just done it myself 2 days ago. Quote Link to comment Share on other sites More sharing options...
oldboy22 Posted November 16, 2017 Author Share Posted November 16, 2017 Good result today I thought the card came off quite easy I was told not to pussyfoot when taking these snap on bits off you make more of a lash up doing that just a good tug. Got to the motor and found the gear had split in its diameter I reckon i will oil and WD everything behind the other inner card before i clag on the"new" motor , thanks Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted November 16, 2017 Share Posted November 16, 2017 good news Quote Link to comment Share on other sites More sharing options...
