IRONMAN Posted November 17, 2017 Share Posted November 17, 2017 Hi, I am fitting a drl relay harness on my 2008 pre facelift focus, but I cant find an ignition live in the engine bay. There is a pos and neg to the battery, and a blue wire to go to an ignition live. I am unfamiliar with piggy back fuses(apparently they have to be installed a certain way) and don't want to go through the firewall. If possible I would like to tap an existing wire. Any help would be much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Loonytaz Posted November 21, 2017 Share Posted November 21, 2017 The orange circled one is ignition live with delay when engine switched off 30 sec or more as cooling fan black circled is ignition live switches off when engine is i have fitted my drl’s on fogs lights in black and switchbacks in orange 2 Quote Link to comment Share on other sites More sharing options...
biff55 Posted November 21, 2017 Share Posted November 21, 2017 There will be loads of ignition lives beneth the engine bay fuse tray , just need a multimeter to find one. Use a scotch lock to tap off the wire if you dont want to use a piggy back fuse carrier. Quote Link to comment Share on other sites More sharing options...
IRONMAN Posted November 23, 2017 Author Share Posted November 23, 2017 On 11/21/2017 at 10:18 AM, Loonytaz said: The orange circled one is ignition live with delay when engine switched off 30 sec or more as cooling fan black circled is ignition live switches off when engine is i have fitted my drl’s on fogs lights in black and switchbacks in orange Very helpful thanks for the reply, I went for the piggy back option under the dash on the rear wiper fuse. Thanks again Quote Link to comment Share on other sites More sharing options...
