Trickytree
Coolant bottle
Whilst cleaning car today popped bonnet to wipe round and noticed coolant level below where I would like it to be. Took twist top off but found like a rubber grommet in there with no visible way of removing. Any ideas how to remove. Car is 2015 Zetec S ecoboost
Sounds like your pressure cap has separated. It's a common problem. You should get it replaced under warranty.
Yes the pressure cap is covered under warranty we had the same problem on our fiesta 1 litre Eco Boost titanium x at first our dealer said it was not covered then the warranty team said if the car was registered after September 1st 2014  it is covered which ours was but they had to test the cooling system before replacing the part. The cap body which was stuck in the coolant bottle was removed with a long nose grips. The cap cost around £13 pound
