mrmetallica
lights coming on then going off and on again
ive just put a new head light bulb in when i was testing that it works ok i noticed that when i turned the lights on they came on then went off and came back on again.
ive noticed the dash does this also.is it something that can be changed in settings with a cable or is tthat how it normally works ?
Take it out again and see if you still get the same fault. The wrong type of headlight can cause all sorts of problems. My granddad fitted a new rear light and every-time he broke, the brake lights stayed on until he turned his lights off.
6 minutes ago, Micro said:
What kind of bulb did you put in? Do you have auto lights?
not sure the number but it had 2 pins h7 i think and i do have auto lights
