Jordan99
DASHCam
Hi all, not sure if this is in the right place, please move if not!
I got a new dashcam yesterday because I thought my old one was broken!
After nearly 2 years of use it started only recording 8 seconds at a time rather the 3 minutes it’s meant to. The new one does the same. Anyone know why this is happening?
Move been using the sam SD card in my old one for the life of the camera. Thanks!
As above...it may have filled up with 'locked' files (because the G sensor is too sensitive) which won't get over-written. You either need to format the card or delete them.
Time for a new card, I suspect. I think the cards have a lifetime defined by the number of write cycles so it's probably life-expired.
I’ve ordered a new card now. Hopefully it will sort it. My dash cam does record but every 8 seconds it’s stops recording for about 2 seconds then just repeats the cycle. It’s more annoying because when it stops after the 8 seconds the screen turns off then on again! See it in the corner of my eye every time I drive
Check your warranty, i had two new sandisks as they apparently had a 10 year warranty!
hold your horses guys, one thing you need to be aware of with SD cards is that no two cards are alike.
also, just because a card is stating its the latest and greatest with mind blowing speeds, doesn't mean it will work.
in fact there is no way of knowing what cards will work in a dash cam.
ill not bore you all to death with the details but the key performance criteria is not the max read speed, its not even the max write speed, these are both sequential, ie, it records and plays like a vinyl record. the important number is actually the undisclosed RANDOM read / write speeds. due to the nature of a dash cam the data isn't recorded in what you might consider a logical order, its written all over the place in the largest free block of space which means when reading and writing the data is actually accessed from all over the card.
So in short, you are just as likely to have a cheap asda card working then you would a sandisk.
What I'm saying is, not go blowing a shed load of money on the card with the expectation that it will work. it probably wont.  and in actual fact after looking in to dozens of cards from many  manufactures from around the world, you more likely to get it working with a slower older card. note the "more likely" you could also get a blisteringly fast new card that works as well, but that's less likely :)
in answer to your question, the card is the most likely problem unless you have some weird wiring setup or perhaps have a dirty live / ground feeding it
Have you tried it without the SD card to see if it stays on?
Maybe try it at home connected to a PC or mobile charger with the SD card in?
Hi Darren, I realise I'm resurrecting an old thread but, noticing your quote above, it occurred to me that in most cases the writing would be sequential. The manual for my cam recommends reformatting the card every few weeks. Once this is done the entire card will be marked as free so one would expect that the cam will begin writing at the lowest address and then sequentially until the card is full. It then starts overwriting the oldest files but since the new ones are the same length surely they will be replaced in sequential order.
nope, that's not the way storage works unfortunately, in terms of the file dates, yes, it will overwrite the oldest one but that might not be recorded in a logical order. Its partly this reason why they tell you to format it (which doesn't actually delete anything, its still all there, you just cant easily see it) stuff gets dumped all over the place.little caches of information that camera uses, settings, temp files, all sorts. Which is why random read / writes are so important, if you think of it like an LP but instead of having it played out in order you might have to skip tracks, forward and back.
Well, that's just the way ordinary PC storage works and why hard drives need defragging but I expected the dashcam would be simpler.
Question? How have you wired the dash cam into the car? Power socket or piggy back fuse?
If you are using a piggy back fuse installing the piggyback fuse (fuse tap) the wring way round can make the dash cam malfunction as you are describing. I installed one the wrong way round and it kept switching the cam on and off continually for a few seconds at a time. I turned the piggy backfuse round and it worked perfectly.
Piggy back fuses have to be installed correctly and you will need to know on wha side the fuse is live.
Fuse 85 I think I used.
I can confirm what you say.  This is precisely the reason why, when installing a SD card in an Android phone, you never select the option to integrate the card into the phone's storage.  Always select portable storage and make do with not being able to have as many apps. Or just pay more for a phone.
SD cards integrated like this, which is just an option for phone makers to skimp on proper amounts of GB, burn out really really really fast.  Just imagine how much writing and re-writing goes on in a phone - much much more than a dash cam.  And when they do burn out? You lose all your precious data.
That doesn't really make sense unless there is a poor connection inside the fuse tap. If you have the fuse tap the "wrong way" around, all that will happen is you will be "double fused" - the power will go through the bottom fuse, and then through the top fuse and out, instead of just in and through the top fuse, and out.
Remember most name brand SD cards have good/lifetime warranties!
I'm going to get geeky now.
Just because a SD card has a long warranty, it doesn't mean it's going to last. Wear levelling is the technique used to preserve the life of a memory card. On something like a video camera or MP3 player, this is fairly easy to maintain. You're pretty always using different sections of the card so it wears pretty evenly.
But with a phone, if you have an app that you always run, you're going to be reading and writing to that app constantly. Every little change will be a read and write cycle.  The only way to have even wear across your SD card would be to constantly move the whole app around it.  I could be wrong, but I can't imagine phones moving apps around like this, so I just wouldn't risk it myself.
I know, i'm just pointing out that you don't have to go out and spend more money :wink: Some cards controllers are also smart enough towards the end of their life to go into "read only" mode (as my SanDisks did to protect the data on them.
What I can say is the the Nextbase Dash Cam I installed did not like the fuse tap being round the wrong way, it kept switching on and switching off. Once the fuse tap was installed correctly the dash cam operated correctly. I can only assume that because the flow from the live travelled the wrong way it caused some voltage fluctuation which as it branched off both live to the dash cam and towards the earth. This in turn made the dash cam turn on and off. Both fuses were rated at 7.5.
If the fuse tap is installed backwards but say you have a a couple of 100W spot lamps installed which necessitates a 20amp fuse and you are draw power from the same circuit as a 1amp accessory fuse it may cause problems.
So while what you say is correct up to a point there is still a wrong way and a correct way to install a fuse tap.
In my case it did affect the installation.
