anto135
Gear selection problem
Ok so when I’m stationary the gear selections fine, I can select each gear fine, when I’m moving however it’s different. I noticed about a month back that it can sometimes be a struggle to get into certain gears at times, the only way I can describe it is when I’m trying to select the gear something is blocking it from engaging so I move it back into neutral and try again until it goes in smoothly, I won’t force it in through fear of causing damage.
 It started mostly with 1st and second but it’s now doing it in third and seems to be happening more often. From memory it seems to be doing it mostly if not always when I’m gearing down.
My 2006 1.25 struggled with engaging gears when in cold weather a few years ago, cured with a new clutch, something to do with the fingers on the pressure plate not applying enough pressure I think
Funnily enough it is a 2006 1.25 and it is really cold at the moment.
Could try this method. I have a mk6.5 fiesta zetec s 1.6 TDCi and I noticed sometimes i would struggle to get into 3rd mainly when I'm downshifting from fourth. I haven't really been noticing this lately but still might try this method out
i can't really see how the cold can affect it other than if it's to do with the gearbox oil thickening in the cold, ie. I can't see how the cold can affect the clutch
It does sound like the clutch dragging as you can get gears while stationary.  Thick oil or a selector issue should still be present while stationary.
Haven't heard of pressure plate fingers weakening in the cold though, if anything they should be stronger in the cold and more soft and pliable when warm. :unsure:
I heard the gears go stiff when the engine gets hot. The engine heat I think heats up the linkage making it go stiff so just lubricating it with heat resistant grease might help the issue. I noticed third gear goes stiff / hard to get into when the coolant gauge goes between the middle mark and minimum mark. I'd be furious if mine is the clutch
The Fiestas do have an issue with the selector drying out, and for the few minutes it takes to clean and re-grease it is worth trying that first in your case.  But don't be too surprised if it doesn't make much difference.
It might even be the synchro if it's just 3rd, 3rd takes a lot of abuse so is usually the first to become weak.  I have to double declutch for 3rd in the Focus quite often or ram it in hard.  Can't see any external issues so probably is the synchro, I'll just live with it unless the diff dies lol.
Something else I’ve noticed just to add if it makes any difference the biting point seems to be quite low. Also when in reverse recently it’s a struggle to get back into neutral from reverse I have to lift and push the clutch back down until it comes out smoothly.
Low bite point and getting stuck in gear again points to the clutch dragging (not disengaging fully).  It's worth checking you've got plenty of clutch fluid (same res as brake fluid) in case it's leaking at all.  But really I think you need a new clutch kit tbh.
