Samandroid1998 Posted December 13, 2017 Share Posted December 13, 2017 Hello, I am looking at installing a sub in the boot of my car. I am going to use a high to low converter to get my RCA's but I was wondering where is best to run the remote cable to? Also I will be using the standard headunit. Quote Link to comment Share on other sites More sharing options...
AlexBartlam Posted December 13, 2017 Share Posted December 13, 2017 when i installed my sub, i ran the power cable from the battery using the passenger side. through the plastics on the bottom of the door then through the rear side plastics where the speaker is, then i ran the speaker wires which link the head unit and sub. i used the driver side. I managed to find a gap where the vent is nearest to the head unit to put the cable through then ran it through the top of the foot well then through to the back using the same method. make sure your ground is long enough and is screwed to bare metal. Quote Link to comment Share on other sites More sharing options...
Samandroid1998 Posted December 13, 2017 Author Share Posted December 13, 2017 That didn't answer my question... I wanna know where the remote wire connects at the back of the stereo... Quote Link to comment Share on other sites More sharing options...
MarksST Posted December 13, 2017 Share Posted December 13, 2017 Either buy a RCA converter that has a remote output on it or, connect it to an ignition switched circuit in the fusebox using a piggyback fuseholder. Quote Link to comment Share on other sites More sharing options...
Samandroid1998 Posted December 13, 2017 Author Share Posted December 13, 2017 Either buy a RCA converter that has a remote output on it or, connect it to an ignition switched circuit in the fusebox using a piggyback fuseholder. Could i not tap into the ignition switch from the stereo? Quote Link to comment Share on other sites More sharing options...
AlexBartlam Posted December 14, 2017 Share Posted December 14, 2017 17 hours ago, Samandroid1998 said: That didn't answer my question... I wanna know where the remote wire connects at the back of the stereo... ah very sorry i miss read your question Quote Link to comment Share on other sites More sharing options...
