vitorbrazil
SYNC 1.1 APIM module configuration
Hi, I'm replacing my AM5T bluetooth module with a D1BT module from a fiesta, and I think I'll need to reprogram the APIM, does anybody know where I can find the configuration for  a SYNC 1.1 2014 Focus?
Try the following AS-BUILT configuration:
7D0-01-01    111F 88C0 0354
7D0-01-02    4000 001A
7D0-02-01    044E 4C00 0078
7D0-02-02    00DB
7D0-03-01    0000 0000 00DB
This configuration is for a SYNC 1.1 APIM module in a Focus MK3 with Emergency Assistance. Vehicles with Emergency Assistance have the additional GPSM module which constantly monitors the GPS location of the car. If a crash is detected by the RCM module the SYNC system automatically calls the emegency services and transmits the GPS location of the car.
Unfortunately not every SYNC based Focus MK3 has Emergency Assistance. Whether the car has Emergency Assistance or not depends on the market (country) and production date of the car. Using a configuration for a SYNC 1.1 APIM module which includes the Emergency Assistance settings on a vehicle without Emergency Assistance results in several DTC codes and some warning messages. On a car without Emergency assistance you can try the following AS-BUILT configuration:
7D0-01-01    019F 0840 03С4
7D0-01-02    4000 001A
7D0-02-01    0452 5300 0083
7D0-02-02    00DB
7D0-03-01    024D 0000 002A
1. Open the Forscan program and wait until a connection with the car is established.
2. Go to the configuration tab (with a processor symbol).
3. Select "APIM  Module configuration (AS-BUILT Format)".
Afbeeldingsresultaat voor Forscan as-built APIM
4. Make a backup (or printscreen) of the original settings.
5. Change and save whatever you want.
7D0-01-02    4000 001A
7D0-02-02    00DB
7D0-01-02    4000 001A
7D0-02-02    00DB
Hi JW1982,
do you have as-built data for a Sony nav w/10 Speakers and Emergency Assistance from a SYNC 1.1 APIM?
i have struggles to find something.. I am from Germany and in Germany nobody before had swapped their SYNC APIM...
Thanks in advance.
At this time I do not have the SYNC 1.1 APIM configuration of the 10 speaker Sony audio system.
To retrieve the correct configuration I need a license plate number or VIN number of a Focus MK3 with a SYNC 1.1 based 10 speaker Sony audio system. Unfortunately these are very hard to find.
