F0CUE
Near 10 year old battery.
During my M.O.T I was advised my battery was needing renewed and also it's the original that came with the car near 10 years that has Lasted! So if you need a new battery find out the Oem ones.
Yep I know but have had issues with it was waiting on g/f listening to radio and had to bump start so defo needs renewed :)
fitted a new batt last week in my old 9yr focus (that now belongs to my partner) batt was the original ford one still in car from 2008.
picked mine up from eurocarparts £43 with discount. fitted in 20mins works like new again :smile:
Lion battery (075 battery - 3 Year Guarantee)Product Code: 444770751
58 minutes ago, F0CUE said:
had to bump start
Thats a no-no on a petrol engine, neat petrol likely to get into the cat
You could say the same about jump starting a car isn't a good idea but it gets done thousands of times a day I bet without issue.
Cheers will check it out. Looks awkward where it's located guess the airbox will need out the way first
As long as its not much longer than the original it'll go in at a slight diagonal. You can pull the plastic sides free for more access
looks harder than it is, just 4 nuts to undo pull the plastic trim off and unclip the batt cables and move to 1 side. then just slide old batt out and new one in and tighten everything back up and away you go. make sure you have the radio keycode to re-enter aswell :smile:
Thanks guys puts my mind to rest stereo is aftermarket so just retuned and relearn mode of ecu.
